LinkAt 2200, as Virgin Pendolino unit No. 390006 was being shunted from the wheel lathe onto the Down Carriage line at Wembley Carriage Sidings South, the signaller at Carriage Sidings South signalbox inadvertently moved CS4 points under the unit, thereby causing an irregular movement, and resulting in the unit becoming derailed by two bogies, fouling the Down & Up Carriage lines and colliding with Pendolino unit No. 390008, the latter of which at the time was stationary on the Up Carriage line, having arrived at 2151 per 5A78, HF, 2135 London Euston – Wembley Carriage Sidings. Upon observing the approaching unit, the driver of unit No. 390008 jumped clear, and was badly shaken. The force of impact resulted in unit No. 390008 leaning at a 45 degree angle.
UK - Pendolino Prang
A low speed collision between two UK Pendolino sets in Wembley Yard at the end of March has been reported on a couple of UK discussion railway boards (see below), but the photographs appeared on a Hungarian site - here
